soldier000
i just switched my cpu to a CM 212 plus on a q6600 and the temps are 32-36 idle is that normal ? im not sure if i applyed to much thermal paste because i only used heatskins with flat bases but this one had small gapes between the pipes so i used thermal paste to fill the little gaps then applied like 2 grains of rice on my cpu after i spread it there was like half a mm on my cpu
in tests with the cm 212 plus with q6600 stock the idle temps are only at 22 degreez
is that to much? should i reapply, if so how should i apply it
the clocks are currently stock
anyone know what type of thermal paste comes with the CM 212 plus? it just says coolermaster thermal compound kit
im thinking of reapplying thermal paste on my gpu to, do i just apply like the cpu?
- M8430F
- Q6600
- IPIBL-LB (Benicia)
- 4gb
- Evga 250 GTS
- 24" Samsung T240HD
- 1680x1050
- 750gb
- PSU
- OCZ GameXStream 700-Watt
- Case
- NZXT Tempest ATX Mid-Tower Case
- Cooling
- Air
- Logitech G500
- Logitech G19
- Bell Max 10
