Nvidia 8800GT Overlock HELP
Prak06
Hey all can someone tell me the best overclocking settings for my standard, factory Nvidia 8800 GT (512mb) - No extra cooling...factory.
Factory *8800GT* :
Core clock = 600
Shader clock = 1500
Memory clock = 900
100% Fan rate at standard = 60 C
Any suggestions?
Thank You!
    Dell Vostro 410
    Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz (4 CPUs), ~2.7
    NVIDIA GeForce 8800 GT
    Creative X-Fi Xtreme Music
    Dell E228WFP
    1680 x 1050 = 22"
    640GB
    20mb Cable
I always abide by common sense when overclocking a graphics card. Generally I start at about a 10% increase and monitor the PC for any errors, over heating or BSODs for a day or two, I personally wouldn't go above 15% with out some extra cooling, mainly because I don't like monitoring the temperatures the whole time.
This is just my opinion and how I do things, it may not necaserily be the best, safest, or most beneficial way of doing it.
Oli
    Apple MacBook, 5,1
    Intel Core 2 Duo 2.4Ghz
    4GB DDR3
    Nvidia 9400m
    13.3" Apple MacBook LCD Screen + 22" HannsG DVI LCD + 21.5" Samsung USB Lapfit Monitor LD220
    1280x800 + 1920x1080 + 1920x1080
    SATA Internal 2.5" 500GB (305GB HFS+, 195GB NTFS) External USB 3.5" 1TB (HFS+)
    Aluminium Unibody
    Apple Magic Mouse
    Apple Late 2009 Wireless Keyboard (US)
    6.33Mb/s up. 0.36Mb/s down.
    Harman Kardon Soundsticks II Speakers
Hello Prak06,
Rive Tuner is your best bet here, (link below), but to be honest you wont see that much of an improvement in FPS, all it will do is shorten the life of the card, and of course raise the temperature, those 8800's can get quite toasty as it is.
If you go ahead with this, go in small steps, as osholt points out, 10% is about it.
RivaTuner v2.24c download from Guru3D.com
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I'd use EVGA Precision or MSI Afterburner.
They are easier to work with if your new to the 3rd party OC utility.
As for settings, Your 8800 GT is running unusually hot for idle (unless that 60c is ingame). So keep it at 100% if it is idle.
I had an 8800 GT SC at 700 mhz core clock (most i could go), 1650 shader, and for the memory somewhere near 975 (take 20-25 mhz increments).
I'd recommend trying MSI Afterburner first as it comes with a built in core voltage setting that lets you have a more stable overclock.
    JUST ME/Custom Built
    Intel(R) Core(TM) 2 Quad Q9550 E0 2.83 Ghz @ 4037.5 Ghz
    EVGA NFORCE 790I SLI FTW Digital PWM
    8 Gig Corsair XMS3 DHX 1600 Mhz DDR3 CAS 9
    2x GTX 480's w/ Koolance VID-NX480's
    Creative SoundBlaster X-Fi Titanium (non-Fatal1ty) Edition
    Acer P243W 24" Premium Series
    1920 x 1200
    Seagate Barracuda 7200.11 1 TB HDD 32mb cache (3 Platters, 6 Heads model)
    Ultra X4 1050W PSU 76A Rated 12V SLI
    Antec 1200 Full tower ATX case
    x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
    Logitech LX310 2.4Ghz Wireless Laser Mouse
    Logitech LX310 2.4 Ghz Wireless Keyboard
    32mb Download, 12mb Upload from Comcast
    300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
there are certain cards for nvidia tht arent recognized like my geforce 9600m GT by rivatuner...so i got rid of it and went to evgaPercision and it worked like a charm and i got a 110 mhz clock out of it on everything...with the shader locked
I got 710/1736/1010 out of mine using a T-rad and 2 90s, FaH runs mid 60's... hence the huge shaders.
My method is start at the highest factory oc and go up 15Mhz, linked shaders, and when you hit a wall start fine tuning.
But 60C idles bad.. my 260s stay there running fah.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
