Laptop still running HOT!!! 140 - 160 F
l)ark_Scorpion
Real SN AT99Scorpion
Power User
My lappy is really warm. Idles at about 140 degrees F, and when I watch a video or play a game, it gets to over 160.
Is this dangerous for my computer? The fan works, and operates. I've tried opening it up and cleaning it out, and it didn't work. Its all like stuck between the heat sink and board or something.
Help plox.
    AMD
    ATI
These temperatures are slightly high but not life threatening for the laptop. The cheap solution is a coolpad for about $20. That will lower the temp by about 10F. The expensive solution is to replace the HDD by an SSD. HDDs produce a lot of heat, SSDs produce quasi none.
You can also blow some mild compressed air thru the vents. Maybe something comes out.
    Dell
    Q6600
    HP w2207h
Meh, I know it isn't my HDD, it runs at like 80 degrees, and this heat is coming from the other side of the laptop where the HDD isn't even at.
I think it's my processor, but it's hard to get the dust and gunk out of the fan/heat sink.
    AMD
    ATI
Heyy,
if you can get the laptop cracked open, you could try taking the cpu heatsink off and replacing the thermal compound, that worked for me on my pc, (my case temp was like 40C and i dread to think what the cpu temp was, so i replaced it and my temp is back to 30C)
I am planning to order a bluetooth module for my AAO751h so thats a great excuse to clean the fan out!
Daniel :D
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Hmm, maybe your battery is hot, whenever i use laptops for a long period of time the battery gets really hot and it cant even sit on my lap anymore. It is normal for laptops to get hot, just make sure your cpu socket doesnt melt. Put some icepacks in a plastic bag (so the water wont leak out) and place it under your laptop, ive also noticed that when the fans are on the bottom, and the laptop is seated on your lap, the air cant get out, so you might want to put it on a solid surface like a table, or even raise it by putting a couple of blocks under the legs of the laptop so it has room for the fan's airflow.
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
Heyy,
you could try one of these cooling pads off ebay, im laying in bed now and my AAO751h get a bit warm, but with this, it gives the hot air room to move, and i have noticed that my RAM gets really hot, that might be whats happening with you....
Daniel :)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
You could also try undervolting your laptop:
The "Undervolting" Guide
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
Running HOT ? I think you are joking , that isn`t hot for a laptop my laptop (Gateway 7809u FX ) At GTA 4 runned 228F ( 108C ) , so your laptop isnt nearly hot as myne :P , of corse my laptop has a nvidia 9800 GTX ,but for some reasons now still in GTA 4 runs at maximum 90Cº , i don`t know why when it was new it ran at 108C , i just wanted to say that dont worry if it runs at 160 F = 77C i think , it isnt hot :P ...
    Gateway FX series 7809U
    Intel Core 2 Duo P8700 Fsb 1066
    4gb ddr3 Fsb 1066
    NVIDIA 9800GTX 1024 mb ddr 3 256 bit
    Conexant Hermosa HD Audio
    Laptop Lcd panel
    1440x900 17" laptop panel
    1x SSD Kingsone hyperX 120 GB
    9 Cell battery with 7800 MAH
    100 mbit/sec (megabit)
just make sure your cables dont melt!
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
I put a paperback book under my laptop and I noticed than I can use it longer before it gets hot to the touch. Before it was shutting down because it was getting too hot.
