Need some advice on this guys
Mutara Nebula
Finally brought my vista experience scores up.
Memory - 5.9
Graphics - 5.9
Gaming Graphics - 5.9
Hard Disk - 5.9
CPU - 4.7
... so we can all plainly see where the bottleneck is :D.
Using an HP Compaq SR5113WM
Asus M2N68-LA - Ivy GL-6
GPU -
XFX 9600GT 512MB DDR3
650W Antec PSU
Memory -
4 GB DDR2 PC2-5300 RAM (system picks up 3.5 GB)
Hard Drive -
320 GB W.D.
Processor -
AMD Athlon 64 X2 3600+ (the mediocre part of it all) :confused:
My question would be if anybody has any recommendations
for upgrading the cpu?
Actually I play FEAR and the expansion packs on Max. settings for about everything.
Usually have V-sync on with triple buffering which helps ...
and disabled Superfetch in both the registry and services. Everything looks
great and plays just as well yet i feel that i'm bottlenecked by the processor.
Would a AMD 64 X2 6000+ or the 6400+ work with this motherboard in my specs.?
Would I have to flash the bios for it to recognize one of these cpu's or would
they be automatically supported?
Been looking around alot on this and i know nothing about flashing a bios
so basically i'm looking for a cheap upgrade over this middle end cpu
that i have now that would be simple to do without jumping through alot
of hoops.
I'm not looking for one to max out my score either but hopefully to bring it
to at least a 5.0 anyway.
Any suggestions would be appreciated. :D
I wanted to overclock the 3600+ and at least get it to 2.5 GH but
these retarded bios' HP likes to use won't let you change hardly anything.
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0 (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
according to these specs, you have the fastest cpu for that motherboard.
Motherboard Specifications, M2N68-LA (Ivy)*
Thanks for the info but i'm not seeing on there where it says that
the 3600+ is the fastest cpu for that motherboard. :confused:
I do see however that it says that the Mobo supports the following -
Athlon 64 X2 with Dual Core technology.
I wonder if that means that all AMD 64 X2 processors would be supported.
if so......... a 5000+ is about $60 and the 3ghz x2 is about $80ish...... :) but the 5000+ will give you a 5.9 score
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
The magic of Google...
From: CPU support / Asus M2N68-LA (Narra3) motherboard
I have the same motherboard Asus M2N68-LA (Narra3) with a phenom 9500 on it and wanted to upgrade the CPU to a Phenom 9950. Before installing the new processor I contacted the HP support and they told me the following:
"your PC is preinstalled with Phenom-9500 Agena 2.2 GHz (95W) processor.
The Maximum approved processor on your PC is:
Sempron less than 3800+
Athlon64 less than 4000+
Athlon64 X2 up to 5600+ (up to 89 watt TDP)
Phenom up to 9600 (up to 95 watt TDP)
    AMD Phenom x4 9600 Agena
    Asus M3A-H/HDMI
    8GB OCZ Fatal1ty PC2-6400
    Powercolor Radeon HD4830
    HP W2408h, Gateway VX1100
    1920x1200, 1600x1200
    Maxtor 200GB IDE (x2) WD Caviar SE16 640GB SATA (x2)
    CoolerMaster eXtreme Power Plus 500w
    CoolerMaster ATCS 210
    MS Wireless Mouse for Bluetooth
    MS Wireless Keyboard for Bluetooth
well there is your answer :) anyway its no more than $100 to upgrade to a good one
    1680 X 1050
    6 Mbs Down 1 Mbs Up
