Hi
I've been having problems connecting wirelessly to the internet using my Fujitsu Amilo Li1818 laptop running Vista 64bit.
This started after i changed my ISP from BT to SKY. Now i can only connect using an ethernet cable, which is fine as the laptop is not too far from the router. For some reason i can't connect wirelessly. I have tried phoning SKY but they are saying it is not a problem with the router as my other devices (phone, ipad, android tablet) all connect properly.
I have carried out all the usual checks like re-setting the router and updating the network adapters from the Fujitsu site. In fact I had to roll back the 'updated' driver because it was giving me the blue screen of death!
As it happens Windows Vista downloaded an update for the Realtek RTL 8139/810x Family Fast Ethernet NIC adapter. So I know that isn't the problem.
Anyway, when i disconnect the ethernet cable and try and connect wirelessly it shows the following when i click on 'Connect to a Network': -
It also does not show any other networks in the area. So is this PPPoE connection causing the problem? I don't ever remember seeing that type of connection before. When i click START and NETWORK it shows my router as ASDL. That also seems odd.
I had another look under DEVICES and Network Adapters and it shows the RTL detailed above. But when i look for the hidden adapters it brings up a whole load of different adapters.
I've attached a screen shot. What an earth are all those hidden adapters doing. They are also enabled. Is my laptop only looking at the wrong network adapter? Is there a way of forcing my laptop to choose Realtek?
I'm obviously guessing here!!
Any help much appreciated.
Until i get this resolved I'm not even going to consider buying a Windows 7 licence which is what i want to do.
Cheers!
NP13TH
- Am i right in thinking the Realtek driver is only for ethernet connections and nothing to do with wireless connections?
- SKY router name, followed by PPPoE Connection. When i click on 'connect' it asks for a username and password. When i enter my ISP name and password it won't connect and asks me to try again.
Cheers!
NP13TH
- Fufitsu Siemens Amilo Li 1818
- Intel (R) Core (TM) 2 CPU T5300
- 2GB
