Wireless connection drops between 30mins to 3hrs in HP Pavilion dv6330ea Notebook PCs
Sivarajan
Model No- HP Pavilion dv6330ea Notebook PC. Refer to the link HP Pavilion dv6330ea Notebook PC | HP® Support
My OS is Vista Home Premium 32-bit.
Recently scanned my system with Intel® Driver Update Utility, it automatically identify and find drivers and keeps the system up-to-date. It detects which driver updates are relevant to our computer.
I scanned my system and here are the results
Graphics Driver
Product Detected NVIDIA GeForce Go 7400 Current Driver Installed 7.15.11.7991 This device is unknown or unsupported. Please contact the manufacturer for possible updates. More information>>
Intel Chipset Software Installation Utility (Chipset INF)
Product Detected Intel® 6, 5, 4, 3, 900 Series ChipsetsCurrent Version Installed 9.2.0.1025
This version is valid.
Audio Driver for Intel Desktop Board
Product Detected Bluetooth Hands-free Audio Current Driver Installed 6.0.1.3100 This device is unknown or unsupported. Please contact the manufacturer for possible updates. More information>>
Wireless Networking (WiFi)(Newer Driver Available)
Product Detected Intel® PRO/Wireless 3945ABG Network Connection Current Driver Installed 11.5.0.32 Newer Driver Available: 13.4.0.139 Download Now File Size: 7.103 MB Detailed Driver Description & Driver Documentation
Wired Networking
Product Detected Intel(R) PRO/1000 PL Network Connection Current Driver Installed 9.12.36.0 This device is unknown or unsupported. Please contact the manufacturer for possible updates. More information>>
So my queries is that shall i proceed with the update or not, whereas there is no new update available from hp update.
My wireless connection is getting dropped between 30mins to 3 hrs, i need to disable and re-enable my wireless connection and then it finds my wireless network and finally connection is established.
OR
Sometimes it doesnt find my wireless network but it finds my neighbours wireless very well. i need to disable and re-enable my wireless connection 3 or 4 times and then network is established.
But when i connect my laptop via LAN i.e with cable then internet doesnt drop at all.
my modem is kept near to my laptop and still some time wireless connection is lost.
q1] Will this update will help to resolve my wireless problem?
q2] Shall i proceed with this update or not?
q3] or how to fix my wireless problem because it keep dropping every 2 or 3 hrs.
Why it dint find my device in my system. why it showed this error This device is unknown or unsported for Graphics Driver, Audio Driver for Intel Desktop Board and Wired Networking
bye
Re: Wireless connection drops between 30mins to 3hrs in HP Pavilion dv6330ea Notebook
Almost one weak passed away.... and still no reply to this post.
For a laptop or notebook, you should only use the drivers provided at the laptop or notebook vendors (HP in this case) support website. They may or may not be the same as the latest from the manufacturer of each hardware component.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
But my model is old and hp doesn't support any anymore. dv6000 models are working well under Windows 7, but they they haven't got official support / drivers for this system from HP.. Last update from hp were somewhat around 3 years back.
Have you reinstalled your chipset drivers? It sounds like to me that you have the wrong ones installed. Try reinstalling from the cd that came with your system. I'm confused. Why are you worried about 7 drivers when you have Vista?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
I don't know which country you're in but you need to go to the specific website for that country to get hp support. I couldn't find that model in the United States support website. I did find this, in case the model number for your system is incorrectly listed- Software & Driver Downloads HP Pavilion dv6-1330ea Entertainment Notebook PC | HP® Support
Hp does support Win 7.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
My model is -- HP Pavilion dv6330ea Notebook PCs and it just supports vista. dv6000 models are working well under Windows 7, but they they haven't got official support / drivers for this system from HP.
therefore i have posted over here to get some help....
Somehow I found your model which I couldn't find before. The page is the same one you posted initially. You can dowload and install all the drivers separately.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
But i found intel pro/1000 pl network connection and intel pro/wireless 3945ABG network connection new version or latest spxxxx.exe from hp site. at present i dont remember the exact spxxxx number and it was mentioned dv6000 notebook series at system requirements. Therefore i need the latest one....
I would try what Townsbg suggested. Just reinstall the originals or the latest from HP. You can always post in the HP forum.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
