Need help deleting wireless networks in Vista
snarfman
I'm wondering if there is a way to remove networks from the list. I live in an apt. building so a lot of networks show up and sometimes my laptop will automatically try to connect to some of them. When I go to "manage wireless networks" in the control panel, my network is the only one listed however.
    ASUSTeK Computer Inc.\N80Vb (Socket 478)
snarfman, long time , no see. how ya been ? The thing about your wireless adapter finding any other radio signal from other routers is kind of hard to stop it from doing, it is suppose to. Morally , you should only use your ISP service , but, plenty of people do have open signals without a password on it and many people will connect to the internet if allowed. I allow my neighbor to use my router, but, i noticed , when i set him up, his computer found 3 routers, mine and another were password locked and only one was open . I gave him my password so as he can use my internet. So, i am not sure you can really stop your computer from " seeing " the other ones out there.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
I have a netgear router and there is a setting called Enable Wireless Isolation. I don't know if that will do what you want. However, if it does, your neighbor probably won't be able to access your network. It's possible you could enable a Guest with Enable Wireless Isolation set. You would just have to try it.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
