Problem recognising wireless device
rosscutting
Hi, I'm looking for some help getting my Micronet LAN PCI adapter to work. I am running Vista home basic and have installed the latest drivers. In manage my devices the device is showing disabled so I click on it and it says "Enabling" and then "Enabled" and then nothing changes. It just shows disabled. In the device manager the wireless card says it is functioning properly.
This is the 3rd wireless device I have installed (I tried 2 Realtek USB adapters as well) and I always get the same problem. Vista's auto installer tells me it has installed the drivers for the new hardware and the installation software all runs no probs but each time the device shows as disabled.
Any help would be much appreciated as Netgear support had no answers :(
    Home assembly
    intel core 2 quad cpu q9300
    p5kpl/1600
    4.0 gig ram
    ati radeonhd 4600 series
    iiyama flat screen
Welcome to the Vista Forum.
I hope that we can help with your problem.
Am I right, ALL your drivers are up to date?
What Model Number is your Micronet?
It may help a little if you click on this link, and see if there is anything that could be of assistance to you.
http://www.vistax64.com/network-sharing/221164-wireless-adapter-will-not-enable.html
Then come back to me.
What security software programmes have you for Malware & Anti-virus.
Sorry, lots of questions,, but they may help.
‘I do not seek to follow in the footsteps
of the men of old,
I seek the things they sought‘
Basho (1644-1694) Japanese Haiku
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
Thankyou so much, brilliant! Zone alarm was the problem, just uninstalled and now im up and running.
Thanks, again!
    Home assembly
    p5kpl/1600
    4.0 gig ram
    iiyama flat screen
Hi, Glad the problem was sorted.
Apologies for not replying earlier,, but was called away from computer for a while.
If you have any further problems please get back to us.
This, may , may have also been the problem with your previous attempts.
Regards,
Kesume
of the men of old,
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
