bjbladerunner
I hope someone will be able to help me here. Over the last year I started losing my wireless connection on my HP desktop running Vista Home Premium SP2. I know my D-Link DWA-542 RangeBooster router is working since the other computers and iphones are working fine on this wireless network.
Each time I lose my network connection, Windows claims that it cannot find any wireless network. I then need to disable the D-Link network adapter and re-enable it to get back my internet connection for a few minutes, hours or days. You can imagine how annoying this is for me now. It uses to work fine a year ago.
Here is the ipconfig stuff if this can help you assist me in fixing this issue.
Thanks a lot in advance!
Ben
Ben
Code:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Admin.Media>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Media
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : D-Link DWA-542 RangeBooster N Desktop Ada
pter
Physical Address. . . . . . . . . : 00-19-5B-53-36-46
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::e4e7:5425:47d3:210d%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, February 11, 2011 9:31:19 PM
Lease Expires . . . . . . . . . . : Friday, February 18, 2011 9:31:19 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 234887515
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0D-8B-07-92-00-1A-92-87-77-D0
DNS Servers . . . . . . . . . . . : 4.2.2.1
4.2.2.2
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : NVIDIA nForce 10/100 Mbps Ethernet
Physical Address. . . . . . . . . : 00-1A-92-87-77-D0
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : 6TO4 Adapter
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:24b7:1584:9fe9:9d6e(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::24b7:1584:9fe9:9d6e%11(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : isatap.{FD5279C7-AFC2-4585-97A3-BD629EE3C
716}
