I need help!
When I'm not using my wired internet connection, I usually use whatever unprotected wifi connections are available nearby. Trouble is, my computer sometimes loses connection, and I can't connect to any other wifi networks because it says it can't detect any. I have to restart my computer and connect again, and this works fine until the connection inevitably drops.
I've tried switching the wifi switch on and off repeatedly and it still doesn't work. Any help would be appreciated and if whoever answers this needs more info about my computer, then I can provide.
Thanks in advance!
EDIT:: I went into Device Manager to see if there were any problems there, and in the 6TO4 adapter properties, I got this message.
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
So I clicked on it, but nothing seems to be happening. Will look around to see if I can get any answers from elsewhere, but again, all help is appreciated.
Thanks in advance!
- Packard Bell
