virgin wireless problems
jamesmacp1974
I have just had installed Virgin Broad band
i have two vista laptops, that do not connect wirellessly but do througha cable
can anyone help as iamfinding virgin helpdesk useless
Are you trying to make an Ad Hoc connection? (Connect 2 or more computers to each other Wireless)
If so please do the following:
Click Start
Click Connect to...
Click on Setup a Connection or network
After that highlight the Connect to an Ad hoc Connection and click Next
Click Next and then set-up whatever Credentials that are required
And you should be able to connect to both computers
Note: you will need to Connect to the Ad Hoc connection for the other computer as if you were connecting to a router
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Josh Many thanksfor the reply
I have two computers that i am trying to connect to the virgin router. they connect but dont let me have internet access.I have been told that there is somthing that needs to be changed in vista.i dont knoehow true this is.
they are the kids laptops and mine that runs on windows 7 runs perfrectly
cheers
Sorry for my Mis-understanding I thought you wanted to connect the Computers to each other ,
When you connect to the router could you please run a Network Diagnostics when you Open Internet explorer and then Upload a Screen Shot of the Issue
See http://www.vistax64.com/tutorials/148532-how-use-snipping-tool-vista.html?ltr=H For More Information
Also Please follow this and run the Attached File at the Bottom of the Post as Administrator on both computers
also Upload a screenshot of the IPCONFIG for both Computers
See http://www.vistax64.com/network-sharing/284688-network-posting-tips.html For More Information
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
