Ok, So, i have four computers one is XP Pro, two are windows 7 and one is Vista. In my XP machine i have a master drive and I also have a slave drive. I would like to share my slave drive (as i have always done) so i can access it from any computer on my LAN. Now, I can map the drive with the windows 7 machines so i know it works and i know its shared correctly with the correct permissions and double click to access it.
When I map this drive in Vista it does add the drive under "network locations" section under my computer. However, i cannot double click to open it. The only way i can open it is to right click and hit explore/open and it works. I would like to create a desktop shortcut to this. When i double click it does not give me any errors, it just sits there; helplessly.
Now, for just fun and games. I created another folder on this XP machine and shared it, and i was able to map to it AND double click to open it. So... i don't know what the difference is other than one is a folder on the C: and the other is an actual HDD.
I have done quite a bit of research and most said to look for autorun.ini (and inf, .exe) in the root folder of the slave drive. Non there. I have ran malware and viral scans on the slave drive and both primary drives. (xp and vista machine). I have disconnected and reconnected this network drive probably 200 times. I have tried to manually make a shortcut (right click > shortcut > path > etc) and it does the same. I have no other path to take. I just don't understand why i can open it via explore or open, but NOT via double clicking it!
Any help would be great!
Thanks
Shaddow
Thanks
Shaddow
