Strange problem while connecting to internet
gameboy80
when i am trying to connect to the internet i am able to connect to the wireless router but i am unable to connect to the internet.
i am getting the following diagram in network center
pc-----------------network------------x----------internet
same problem with using wired connection also.please please help
Click on the x it should fix it or give an error message.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
This may be due to profile change by your ISP, recently my ISP increased my speed from 8MB to 24MB and the DLM(Dynamic Line Management) switched my profile automatically. I rang my ISP and they have disabled automatic DLM, that fixed the problem.
This suggestion only applies if you are in UK and even if you are outside UK worth a try.
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
