serious problem with youtube
GradeAbra
Well, now when i try to watch video in youtube, it only shows a black screen and no play button at all. I tried installing Java updates but it does not help. Anyone know what should i do?
What internet browser are you using?
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
No problems here with IE8. Need to use the 32-bit browser though (Flash required).
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
    HP Pavilion Elite
    6.O GB RAM
    1440x900 & 1440x900
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
Try this:
  1. Temporarily disable popup blocking software installed on your computer to test.
  2. Allow YouTube.com as a trusted site in your Firewall software.
  3. Ensure other applications like Quicktime, iTunes, Real Player, or Windows Media Player aren't set as the default streaming application, as this might affect the video player.
    HP Pavilion Elite
    6.O GB RAM
    1440x900 & 1440x900
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
