Remote Assistance\Remote Desktop Connection
prukeyhi
Workaholic
Power User
Hello!
These are two computers connected via the Internet (not a home network)
1 - Vista Home Premium
2 -XP Pro
* Trying to use the built-in Remote Assistance software installed on 2 computers:
I can control in Windows Vista through the xp but not vice versa ...
The problem is known?
There is a solution to the problem?
** Trying to use Remote Desktop Connection software (not installed
In Windows Vista?), I can control the xp through in Windows Vista but not vice versa ...
    LENOVO G-530
    # Intel Pentium Dual-Core T3400 (2.16GHz, 1MB L2 cache, 667MHz FSB) # 15.4-inch glossy 16:10 display (1280x800) # Intel Graphics Media Accelerator 4500MHD # 3GB DDR2 667MHz RAM # 250GB 5400RPM HDD # SuperMulti DVD+/-RW Optical Drive # Broadcom WiFi (802.11b/g), 10/100 Ethernet, Modem # 6-Cell 11.1V 53WHr Battery http://www.notebookreview.com/default.asp?newsID=5022&review=lenovo+g530
Error message about Remote Assistance:
Here is a screenshot of an attempt to control the XP computer through Vista. The error appear Before I'm concerned / clicks something. If I approve the message OK -> Software shuts down...
- Can anything be done?
    LENOVO G-530
