Problem with my Realtek RTL8168 Ethernet - Please Help
vistawoot
My laptop (Vista Ultimate x64) got hit by a malware recently, removed it and is now clean. But after cleaning (malwarebytes) and doing a registry repair (using advanced systemcare pro), i was not able to connect to the internet. When i checked Device, the "Realtek RTL8168/8111 Family PCI-E Gigabit Ethernet NIC (NDIS 6.0)" had a yellow astrix to it. I tried uninstalling the driver and re-installing the driver from the cd. But still the yellow astrix remains and the internet does not work. I tried uninstalling the driver - rebooting - reinstalling - rebooting - still same result.
Please let me know what i should do to make the internet work. I really don't want to do a reinstall of the OS again - have a lot of programs and would be a pain to reinstall each of them.
Thanks in advance.
Im not familiar with systemcare pro, but you could try using the built in "sfc /scannow" command to check the registry also. Did you try rolling the driver back? or going online to find the latest driver for it?
    Toshiba Laptop A505 S6965
    Intel Core2 Duo P7350 2.0Ghz
    4Gb DDR2
    ATI Mobility Radeon HD 4570 (512MB)
    16in.
    1366x768
    500gig
    10Mb/896Kb
Why did you need to use a registry repair tool ?
It's possible that the program may have deleted a key needed for the Ethernet chip.
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
    Intel(R) Core(TM)2 Duo 8400 @ 3Ghz
    ASUS P5K Premium WiFi-AP - Black Pearl Edition
    4Gb Crucial Ballistix (4 x 1Gb @1066Mhz)
    ATI Radeon HD 4800 Series
    Using HMI through ATI card
    TV - Sony 100Hz LCD
    1360 x 768
    64Gb OCZ Solid State HD (SATA2) + 400Gb SATA
    Silverstone
    touchpad
    Logitech wireless
Uninstall Adapter
Disconnect from internet to make sure the device driver does not install.
Now install Adapter
Install driver from disc.
Now reconnect internet.
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache 1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
