bright1064
Had problems with my computer over the last few weeks, and I think I have finally got the thing up and running again. Had to remove some RAM, restore back to factory settings etc. All because it kept freezing on me after a while, but my net connection (via wireless) was fine.
Obviously after I restored it to factory settings I lost my wi-fi (Netgear) sofware, and so last night I installed it again and put the adaptor into the USB port and so that is done and installed. It shows a connection and the computer can see my household wi-fi netowrk with a good signal.
But I can't connect to the internet, or even tweak my settings. Never had this last time when I first set up my wireless connection when I got the PC.
When I look on the desktop toolbar there is the icon of the two computer screens with the red cross through it. If I hover over the icon it says "Connection status: unknown. Access is denied"
So I went to try and have a look at or tweak the settings under the Network & sharing centre in my control panel and when I opened that up it didn't give me any options it just read "Unknown. Access is denied"
Can anyone help me?
Thanks
Can anyone help me?
Thanks
