Strange problem with connectivity to internet
vitrag24
Hello,
I'm using windows vista home premium 32bit on my HP dv6226tx with latest updates installed.
I'm having strange problem of connectivity frequently.
After i browse for some duration or open more tabs, i dont know which reason, i can't open any website other then google,gmail..
Though i can connect and browse any site at same time on my ipodtouch.
Both interner explorer as well as google chrome doesnt open any site when such happens but google,gmail works..
After i restart pc, it works again..
sometimes if i wait and dont restart, it starts working and again stops mostly.
any diagnosis?
wht shd i do?
Thanks.
I have the same problem with Google Chrome - it begans to crawl and will take FOREVER just opening Google or Gmail - I uninstalled and use Firefox instead, and now I'm fine. Sorry I don't have a better answer than that. :huh:
    AMD Athlon 64 X2 Dual Core 5000+ 2.60GHz
    Biostar N68PA-M2T 1.0
    3006MB
    Nvidia GeForce 9400GT
    Envision 22" widescreen
    1680 x 1050max
Hello,
any diagnosis?
wht shd i do?
Thanks.
The tabs that are open are they bandwidth consuming sites? i.e. Youtube, CNN, or any other in browser flash video site? Downloading while browsing? Torrents?
I am still runnning a beta version of chrome for Linux and have no such problems. I doubt a final version as the one for windows has a problem like that.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
Hello,
any diagnosis?
wht shd i do?
Thanks.
Nope, simple sites no download in background, and both IE and Chrome have problem when one stop other too.
Hmm, this isnt a router problem, as you can still surf on ur ipod. You can try firefox, or restarting your browser whenever this happens (i mean killing the actual process).
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
havent installed firefox as new version was too slow due to lots of preloaded plugins..
if i'll encounter error again, i'll install it and disable all plugins and test it..
rightnow using IE8 and chrome.
It could even be a power setting on the machines wireless card. If the iPod surfs with no problem there is something wrong with the machine.
From a command prompt type netstat -r -v and see what you get.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>netstat -r -v
Interface List
9 ...00 19 d2 59 0a 9e ...... Intel(R) PRO/Wireless 3945ABG Network Connection
8 ...00 16 36 f2 0a 63 ...... Intel(R) PRO/1000 PL Network Connection
1 ........................... Software Loopback Interface 1
13 ...00 00 00 00 00 00 00 e0 isatap.{0E9D2BEB-C167-4A3E-A298-89ADB6ECD244}
15 ...00 00 00 00 00 00 00 e0 isatap.{F86A0029-30A0-4534-A61D-E81EAF3B0CB8}
10 ...02 00 54 55 4e 01 ...... Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.3 20
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
169.254.0.0 255.255.0.0 On-link 192.168.1.3 296
169.254.255.255 255.255.255.255 On-link 192.168.1.3 276
192.168.1.0 255.255.255.0 On-link 192.168.1.3 276
192.168.1.3 255.255.255.255 On-link 192.168.1.3 276
192.168.1.255 255.255.255.255 On-link 192.168.1.3 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.3 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.3 276
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
10 18 ::/0 On-link
1 306 ::1/128 On-link
10 18 2001::/32 On-link
10 266 2001:0:4137:9e76:3892:27d9:3f57:fefc/128
On-link
10 266 fe80::/64 On-link
8 276 fe80::/64 On-link
13 281 fe80::5efe:192.168.1.3/128
On-link
10 266 fe80::1490:3412:aecd:f441/128
On-link
10 266 fe80::3892:27d9:3f57:fefc/128
On-link
8 276 fe80::7536:ced9:bb78:630d/128
On-link
1 306 ff00::/8 On-link
10 266 ff00::/8 On-link
8 276 ff00::/8 On-link
Persistent Routes:
None
I dont know how to interpret..
firefox doesnt come with any plugins or addins installed from any of the mozilla sites. did you d/l from elsewhere? or another possiblity you have been hit with malware there is malware that plants fake plugins and would also explain the slowdown/hangs.
have you scanned for nasties yet?
    home brews
    pc1 msi k7delta, pc2 asus kn79txd evo
    pc1 2gb crucial, pc2 4gb gskill ripjaws
    pc1 bfg 7800gs, pc2 shapphire 5770 vapor-x
    onboard
    corsair hx
    jeantech phong
    pc1, handmade waterblocks,passive cooling, pc2 corsair h50
    logictech mx510s wired
Well, no malware , plugins are by default due to preibstalked programme Luke adobe flash, roboform, idm etc.
