Hello all. I am troubleshooting a Vista machine that will not connect to the internet. I share an internet connection at home through a router using dhcp. I can confirm that it works as I have currently 4 machines connected (3 wired, 1 wireless) and they all connect just fine.
By the way I am using a wired connection for said machine.
The output of ping and an ip address states:
Ping with a url:
This machine was working about a week ago. Nothing was added (hardware/software) that I know of. Or at least that the kids will admit too!
I did note one occurrence, and that is, when DHCP gets an ip from my router it is 169.254.***.*** where as my router is configured to begin the adresses in 192.168.3.100 and up... Further, I don't receive a DNS from DHCP.
If I manually input an IP (in my range/subnet of course) I get the same output from command line and Network and Sharing Center.
I've tried
disabled/enabled the device,
changed eth cables.
Diagnose/Repair just states that I'm not getting DNS from my router.
I know this issue has to do with something in windows and not the hardware because I have booted off of a KNOPPIX linux cd and it connects just fine
Any ideas would be greatly appreciated. I would like to get the children off of my laptop
P.S. I am currently scanning with Malwarebytes, AVG, then Spybot so I will update if anything changes upon completion. Thanks.
Code:
General failure.
Code:
.....host unkown....
I've tried
Code:
ipconfig /flushdns
changed eth cables.
- HP nc8430
- DuaL core
