Newbie!
I am re-opening the thread on Bluetooth Mouse loss when coming out of power save as I cannot find any solution to this, or mention of the situation I have!
I have a Toshiba Sat Pro running Vista Home Premium 32bit with Toshiba Bluetooth Stack, Logitech 5000 mouse & keyboard.
This problem has only recently started & must be the result of a MS security download!
When I come out of power save I noticed that my Bluetooth icon was static, when I checked the Bluetooth settings I found it was showing Bluetooth as enabled, I then set it to disable & then re-enabled straight away and got my connection back, (this also affects the keyboard!)
Maybe this info will generate an idea regarding the problem.
- Intel Core 2 Duo
- 2 Gb
- Logitech 5000
- Logitech 5000
- 2.2 Mb
