First to get something out of the way:
Motherboard: ABIT IN9 32X MAX
This card has 2 GBit Ethernet ports.
Alright, my problem: I can't connect to the cable modem at all. There is just no way to get it working for whatever weird reason. I don't get assigned any gateway, I don't get any IP (so it rewerts to a funky 169.whatever adress).
Now, I used to have this exact cable modem connected to my computer, with internet, 2 days ago. I would share internet trough the other ethernet port that I didn't use to another computer, and everything would work. Then we just had our internet crap on ourself the other day. And it was my computer that just felt like killing the internet. Ever since: My computer wont connect to the internet at all, it wont even communicate and get ip from the cable modem.
And before I get any questions on it: Took the cable from the cable modem, and jerked it into the other computer, and presto, I'm talking to you guys. No problems at all, and it worked instantly. Didn't even have to reset or restart or configure anything on the other one. Sadly the other computer only has 1 Ethernet port, and the cable modem wont work with any routers inbetween, and also only has 1 Ethernet port on it (yay for stupid hardware *sigh*). So with that and that it working not 2 days ago, makes me really wonder what is going on.
Then I go looking for a router I have around, right? I plug that into the computer that aint getting signal to the internet, right? Presto, I get assigned IPs, gateways, and I can browse to the router config pages via Firefox, with ease.
But, I just don't get why I can't connect trough the modem that I have been using for the last month(s). This is just silly and ridiculous.
What I've tried:
- So when this issue occured, we waited for about 30 mins, cause this crap happens, and we expected it to come back. Didn't so rebooted. No dice.
- So, after awhile I suddenly got connection back on the other port. And I could use internet, but I couldn't share it, cause the port I used, wasn't working. (POST note: I know now, that it was cause the damn thing was hibernating or something, I dunno... It was a static light on the back of the port, no blinky blinky...). While nice and all to have internet on it, I needed it for both computers, so back to troubleshooting!
- I re-installed some drivers back and forth, to see if that helped. No dice.
- I now can't get ANY port to work. Jippi...
- Installed Win 7 to try that. No dice.
- Re-installed to Vista. No dice.
- Noticed that I had static lights on my ethernet ports. Okey, funny... Turned of computer, janked power cables out, reset CMOS, and let it go for an hour. Came back, put everything back in order, and got it up and running, and found my ethernet cards again, installed drivers and all, but appearently: Still can't communicate with cable modem (ie, get any IP or gateway from it).
- I've tried a number of drivers, and similar solutions to the one above with zero luck.
- Reinstalled Vista. Again. Not working. Checked if I could find the router that I found earlier. Jupp, that works. No action with cable modem though. Weeeeeiiiird....
- Juggled some drivers again. No dice.
- Juggled some CMOS resets again. No dice.
- Some BIOS flashing. No dice.
As a side note: Driver wise I've tried the drivers at Abit's page (for my MB) aswell various Nvidia drivers, with no luck what-so-ever!
Similar problems, and solutions that didn't work:
List by thread names...
- http://social.technet.microsoft.com/Forums...8a-b37fdf29e275
- http://forums.hexus.net/abit-care-hexus/16...indows-7-a.html
- hey! nvidia nforce ethernet problem
- Also there was a few similar post here on the forums, but nothing I tried of those that I think pertained to my issue helped.
PS: I'll link my sources to what i've tried as soon as I can find them.
What the HELL IS GOING ON????
Why would it just die out like this? Any suggestions is taken with open arms.
If you need any screenshots, images or transcripts or whatever, I'll provide them for you! Just help me get this working, as I'm dire need of both computers for work and gaming.
Sincerly,
Calen Cinderheart
End note: I'll update with progress, as soon as someone brings me some insight to this problem and suggestions.
What I've tried:
Sincerly,
Calen Cinderheart
- Intel(R) Core(TM)2 Quad CPU Q6600 @2.40Ghz
- Abit IN9 32X MAX
- 2GB
- NVIDIA GeForce 8800 GTS 512
- Realtek onboard thingie
