Wireless LAN connection problem
argbey
Dear all,
I use Window Vista. I have no problem connecting to the internet if I use a normal cable but when I use my wireless LAN AP, my PC can detect the wireless router with no problem at all but then my PC could not connect to the Internet (the Earth). My wireless router is a IEEE 802.11 LAN. I believe this is related to some codes or something that I should enter? Could anybody let me know what to do? thanks!!
Dear all,
Are you using any type of encryption (which you should)? If so, you may need to put an encryption key on your pc to allow access.
Also, FYI, WPA2 offers good encryption.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
You set up wireless access security on your router yourself. You typically access the setup through a browser with an address like 192.168.1.1, provide the password (the default is typically "admin" with no username), and then see a series of pages and tabs.
Somewhere in there, you will have a Wireless page or tab, and then probably a Wireless Security page or tab -- with some options for the SSID broadcasting and different forms of access control. If you've set up access restrictions, you see them there.
BTW, it's best to connect to the router via a wired connection when you do this, that way, you don't get hung up on wireless security while trying to configure it.
    Home built
    Athlon x64 4400
    ASUS A8n32-deluxe
    OCZ 2GB low-latency 3200
    ATI X1600
    B-enspirer CMI8788
    Samsung 24-inch flat panel
    19290x1280
    WD 320GB SATA II
    350 watt enermax
    Antec PS180
    Logitech wireless
    Logitech G15 gaming
    Broadband -- 15MB
Mark,
For something cool, you can flash your linksys from www.dd-wrt.com | Unleash Your Router
It's linux-based and a great alternative to the standard Linksys flash.
Yeah, never have wireless admin. Security issues, for one.
Argbey, you need to connect to your wireless router with cable to see if security is enabled. Did somebody set this up for you, buy it used, or is it new out of the box? Refer to your instructions for setting up security. You will want WPA2. Set for G or N unless your wireless adapter is B.
What is the make and model of your wireless router?
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
