vista internet problem! PLEASE HELP!
gtgirl101
hi guys,
k so i got a virus tuesday, and i re-installed vista,
i have a dell inspiron 1525 for about a year now and the CD to reinstall vista
came w/ it so yeah
anyways
i have reinstalled vista,
and everything is working except my internet!!!!
i am using my brother's pc right now and this internet is working fine, my dads laptop is working 2!
we have a netgear wireless router
and vista is NOT recognizing it!
please help, cause i've called netgear and they've said that the problem is w/ dell
and these dell idiots wanna charge me $200!
so i figured i would ask here
plz plz plz plz help,
i need my internet to install itunes and stuff
thnx
gt
You just need a driver for you network card. If you fill in your system specs (lower left corner of your posts) so we know what hardware you have.
then we need you router/modem info
Btw welcome to vistax64
I have a 1525 myself
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
I m sure you must have received some CD with the wireless router. As said by Ken, its just the driver that you will need to install and then configure the wireless router(a bit painful).
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
wait wat do u mean?
like the service number and stuff?
wk well the netgear model is WGR614
the service card #: 1SV8967BO444C
TA-100-12855-01R23
MAC: 0024B2918BFA
srry if thats not wt u needed, i dont really no anything about all this
wait wat do u mean?
TA-100-12855-01R23
MAC: 0024B2918BFA
what model of network card? If you dont know you can take the express number on the computer and go to support.dell.com click on drivers and downloads, and enter your express number. It will find all the drivers you need. just need to tell it if you are 32bit or 64bit. You probably are 32bit.
download the drivers and install them, then reboot and it should work
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
wait wat do u mean?
TA-100-12855-01R23
MAC: 0024B2918BFA
What's the name and model # of the router?
Should be something like belkin, d-link or netgear.
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
express number is on the bottom of the computer its something like 1qncgc6
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
here is the direct page for your computer model. go here download the network driver
Drivers & Downloads
ken
btw welcome to vistaX64. you may also want to download other drivers from here later on.
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
kativa, lemme tell u i cant go on the internet @ all!
do i download this on the computer the router is connected to?
and ken express service code:
29650603969
yes. then using a flash drive, copy it to your computer and install the driver.
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
29650603969
that number isnt valid there is another sticker on the bottom that is like 6-8 letters and numbers but we really dont need it now.
You already have where to go. download the driver to the other computer and either burn it to cd or copy it to a usb thumb drive. then install it on the computer that cant connect, reboot
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
ok you have a file that you double click on right? what is the exact error message you get?
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
