Hello, I have been passing through this forum while researching the problem and after an hour of not finding a solution I thought I might post my own thread.
I will try to explain the problem and the things I have already tried as completely and clearly as possible.
The problem is that my LAN network does not work. Under the manage networks tab, it has the status: " network cable is unplugged."
To be sure of this, I did a quick ipconfig /all and Ethernet Local Area Connection returned with:
Media State ........ : Media Disconnected.
I am living in a dorm room and we have Ethernet ports built into the walls and are not allowed routers. My roomate can connect to the wired system fine, so I don't believe that the port is the problem. We have also switched out all of the cables to make sure that none of them were problematic. They all work.
So I did some research to try and fix the problem and this is what I did.
1) I checked the device manager and there are no problems with my network card. The device is said to be working properly, drivers are updated, and their are no auxiliary network drivers with errors.
2) I have completely de-installed the network card from the device manager and rebooted, allowing windows to relocate and re-install the device.
3) I went into my Lan Network settings to make sure that both IPv4 and IPv6 would automatically assign IP addresses.
4) I went to the LAN adapter's configuration and played around with all of the flow control settings. Making it do all sorts of full and half duplexes of varying bandwidth. None of which worked
5) I cursed a little (okay, I may have cursed alot) in frustration.
6) I went to the LAN adapter's configuration and made sure that Power Saving mode was turned off (just incase windows was somehow auto disabling the device)
7) I performed netsh int ipv4 (and ipv6) reset commands.
I did not perform a winsock reset command because by this point I was almost sure that everything about the network card and my protocals was pretty ship shape and that it must be some sort of hardware malfunction.
So first off, does this sound like it could be a hardware malfunction? It is a laptop so I don't really have a way to manually remove and swap out network cards.
Second, if someone can better explain why a winsock reset would help after all of the above didn't, then I will gladly do one (also if i performed a winsock reset, would I have to re-setup the wireless printer in the dorm room).
and lastly, if anyone has any new tricks or suggestions about what may help please let me know I would be ever so greatful.
Thank you
Thank you
