Wireless card driver problems in Vista 64The
svraj111
I bought a Desktop running Vista home premium 64 bit OS.
The PC is recognising the wireless card which i bought seperately but I'm unable to install the driver.
The card says that it supports Vista & the company also sent me an email stating the same.
I am enclosing the Card details.
Sabrent PCI-G802 Wireless LAN 802.11g PCI Network 54MPS Wi-Fi Card Adapter - VISTA Ready
It uses RaLink RT2561 chipset.
Any suggestions? If i need an updated driver can someone forward a link forthe same? I couldn't get the Drivers from Sabrent .com.
The driver is from the chipset company Ralink - this website too doesn't have the driver
Thanks and Regards
Thanks and Regards
ive found the drivers on sabrent.com and its a very easy site to navigate but hard to link the drivers, ive taken the liberty to download the drivers and re-upload them to vista forums for you, the zip file below is what you need.
simply open the zip folder and look for "setup.exe" and install your new wireless card :D
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Hi Needs
Thanks for the file.
Unfortunately I was able to unzip only some files.
The most important file setup couldn't be unzipped - WinRar says that access is denied - total 8 files couldn't be unzipped - all .exe & .sys files
I was able to download the driver from I/net - Home - X-DRIVERS.COM: eXtremly full software portal and Wireless Driver Download
They both were 27.9 MB couldn't unzip either one of them- same WinRar access denied message.
Any suggestions?
Regards
Raj
Hi Needs
I aws able to get the driver from x-drivers.com & the card is working fine.
My Winzip was corrupted on the other PC & it was trying to open the files in WinRar hence the error message.
Thanks for your help.
Reagrds
Raj
no problems, strange that winrar had that type of problem, ive never had that issue with winrar at all, glad you got it sorted.
    16Mb Sky bb
