12345matic12345
Hello,
In XP Professional this worked like a charm and I can't make it work under Vista x64. I have a laptop with a VPC image installed. I tell the VPC to use the Wireless connection - our company's internet facing connection. I use the wired connection to face our internal network and interact with our IE applications.
The 2 networks are truly seperate and having nothing to do with each other. The wireless is a 192.168... and the internal network is a 10... network.
How can I get this to work in Vista x64? It worked in XP Professional and there was nothing special that I had to do. Help and or comments please.
Thank-You for your replies.
