My Lenovo laptop will not automatically connect to my home wifi at boot up although it is set to connect. All of my other computers, XP & both 32bit & x64 versions of Vista, will automatically connect. My network is secured and that computer does have the network & key saved. The Lenovo will manually connect to my network.
The Lenovo laptop: Y430 series laptop running Vista x64 Home Premium
My network: secured DLink Dir-655 Xtreme N gaming router connected to a Motorola cable modem.
The Lenovo has another quirk: on battery, screen will go off after maybe a minute even when the laptop is being actively used. Power settings, which have been checked & rechecked hundreds of times, say the the screen should not go off for 15 minutes while on battery.
- Custom mATX
- AMD Athlon X2 5600+ Brisbane 2.9Ghz (dual core)
- Asus M3N78-VM Green
- Kingston 8 GB DDR2 PC-6400
- PNY NVIDIA GeForce 9400GT 512MB PCIe
- Samsung 22", Samsung 24"
- WD RE3 320GB (WD3202ABYS), Samsung SPINPOINT F1 640GB (HD642JJ) External Drives: WD MyBook Essentials 500GB, WD 120GB, an old Maxtor 80GB. Portables: Simpletech 160GB, WD Passport 250GB.
- PSU
- Corsair 620W modular
- Case
- CoolerMaster Elite 341 mATX
- Cooling
- Thermaltake TR2-R1
- Microsoft Laser & Logitech Marble
- HP Elite Keyboard
- Cable
- Other Info
- Printers: HP Photosmart C7280, Oki-Data 3400n, HP Officejet 4300
