necr0potenc3
Hello everyone.
From time to time, specially when I`m doing heavy uploads or heavy downloads my connection goes from full internet to "Local Only" or "Limited Connectivity". Thus, all internet access is lost until I reset the connection (disconnect and connect again). When the connection is reset, the problem is solved and the issue is fixed, that is, until it happens again a few hours or days later.
I`ve found out that this is quite an usual problem for all Vista users, most of my friends have this same problem and I`ve seen hundreads of posts in the internet about it, but no solutions were found.
I`m running Windows Vista Home Premium 64bit on a HP dv7-1245dx notebook. I have another PC which also runs Vista 64bit, two notebooks and a PC that run WinXP.
From all of these machines, only the ones running Vista are affected, I do not have this problem with the machines running WinXP. All machines are wireless (connected through WIFI) but the PC running WinXP. I`ll use my main notebook as the scenario for troubleshooting.
DHCP is enabled in my router, all machines receive their IPs and DNS without problems. My router`s firmware and all drivers are up-to-date, including Windows. I`ve run Microsoft`s router diagnostic tool and it passed all tests. My router`s firewall is disabled and so is Window`s firewall. I`m currently using Avira Antivir. Before, when I used Kaspersky I had the impression that this problem was much more frequent (Kaspersky listens on all in traffic)... but I might be mistaken.
I`ve already tried disabling IPV6, automatic network discovery and others, none worked. I`ve also tried setting my IPv4 and DNS ips static and that also didn`t do the trick. I did not try a common method of disabling a DHCP packet flag in the registry because I am aware that my router fully implements and is proof-tested on DHCP and all machines in my LAN are correctly assigned their IPs, thus that should not be the problem.
Below are my ipconfig/all info for both scenarios, when connection is OK and when connection is Local Only:
CONNECTION OK
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Daniel>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Kartofel
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5007 802.11b/g WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-21-8A-13
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::7468:4dfb:9b5f:8473%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, April 27, 2009 1:03:52 PM
Lease Expires . . . . . . . . . . : Thursday, June 03, 2145 7:39:49 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek RTL8102/8103 Family PCI-E FE NIC
Physical Address. . . . . . . . . : 00-1E-EC-FD-64-DD
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.{86385F4F-6F49-4474-81BC-317BD00E5
89F}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.{5D4A7830-7175-4DD4-9638-473F36D21
308}
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : 6TO4 Adapter
CONNECTION LOCAL ONLY
Lease Obtained. . . . . . . . . . : Sunday, April 26, 2009 1:31:56 AM
Lease Expires . . . . . . . . . . : Thursday, June 03, 2145 7:30:41 PM
89F}
308}
PS: I do not mean to be rude or cocky but I wish to keep this thread clean. Please disregard posting if you haven`t read the entire post. Do not post things like "Keep resetting your connection, that`s the fix!" because that is not a fix, it is a simple bypass around a bigger, unknown problem. I use this notebook on VNC a lot (I dont like taking it to some places of my town) and sometimes I just cant do it because the connection went Local Only, thus I can`t access it from the outside world (internet) and fix the problem if I`m not home.
PS2: To those who have read it this far, thank you for your time reading about my problem and for your future contribution. All ideas are welcome!
CONNECTION OK
89F}
308}
89F}
308}
