I'm trying to make a standard LAN just for gaming between the 2. The pc has linked to Vista in the past but that was via a router, I then moved and now got my self a lap top. Started the LAN process, setup the lan on the XP, told it what workgroup, told the Vista what workgroup, reset both.
Its running through 2 patch cables and a hub right now and the xp gets a connection fine, but the vista dont even say it has local.
If i ping the xp from the vista it says my laptop IP with the reply from and gives the message - Destination host unreachable,
I've tried with all firewalls off and activated the private network and allowed the options for network discovery and file sharing.
I've even tried manually setting the IP addresses to 192.168.0.1 and 192.168.0.2 and still no luck. The vista wont accept a gateway tho which i always used to set to the pc's own IP when doing LAN.
Anyone have any idea's? been wracking my brain for 2 days on this lol.
Thanks,
Craig.
PS the net con im using is wireless so has nothing to do with the cable'd LAN.
*EDIT* I also have the patch from microsoft for XP to make it easier to see vista computers.
Thanks,
Craig.
