Network (wired and wireless) loses connection, needs restart
dcde2004
Hello,
I have a problem, and it appears to have been for there for a while. I have 2 wired computers on my network, and maybe 2-4 wireless computers, that aren't always on.
I use 2 computers, one laptop wireless, and one desktop wired. (laptop = XP, desktop = Vistax64)
The laptop one day suddenly kept dropping connections to the net, but a re-enabling of the network card would usually solve the problem. Then it would drop randomly again after that. I thought it was something wrong with my computer, so I reformatted it, but the problem kept coming back. But now I don't use that laptop much anymore so that doesn't worry me.
However, I bought new tower desktop (the wired one) with high end specs (i.e., Q9550 64 bit processor and whatever else comes with a high end computer), and this uses a wired connection to the router. I've bought it for only 1 month. The ethernet cable is also new.
The router is a D-Link DI-624. (2.5-3 years already)
Less frequently, this desktop also started disconnecting randomly, but more of these disconnections occurred during the times I would use this to play online Warcraft 3 games, rather than me surfing the net and using MSN Messenger.
The difference here is that, with the desktop, I can't re-enable the ethernet card, because in the Device manager, the window crashes when I right click for the drop down window on my Network Adapters list. (This doesn't happen when the network is working). The Networks and Sharing Center also takes ages to load, and sometimes never loads, just hangs. Everything else in Windows works perfectly fine.
I am not sure if they are the same problem. However one other laptop (Windows vista) met the same issue as the desktop. It had the same crashes in the same places, the network sharing centre would hang as well.
For the desktop and that other laptop, only a reboot would solve the problem. I don't know if it is because the Vista laptop accessed the networks using windows and if windows had an error then the connection couldn't be repaired. However, with my XP-laptop, the network was managed by Intel Pro Wireless, and the problem could be solved with a simple reenabling, but would recur MORE FREQUENTLY.
I have yet to check the network IP status of the computers during a connection-down, but pulling out the cable to my desktop does not solve the problem. Neither does resetting the router.
What I do know is, for my laptop and my desktop, a disconnection on the laptop doesn't mean a disconnection on the desktop. Vice versa I don't know as of yet.
The disconnections for the laptop seemed to start after I assigned WPA-TKIP keys to the network, but an ethernet cable connection to the desktop means that the problem should be independent of the pass keys. So the only filter for the network for my desktop is the MAC filter.
With the second desktop that I mentioned, I have yet to see it disconnect or hear of other people complaining about disconnection (maybe because I rarely use it).
Has anyone else experienced this problem? I don't want to get a new router before knowing the problem because if it isn't the router then I would have used my money for nothing.
Thanks! [Edit: ALL MY DRIVERS ARE UP TO DATE ACCORDING TO VISTA, INCLUDING FIRMWARE FOR THE ROUTER, OF WHICH NEW FIRMWARE IS UNAVAILABLE ON THE DLINK WEBSITE]
-dcde2004
Don't know if this may help...
I was losing connectivity and then found out my old cordless phone ( house phone ) was a 2.4 GHZ phone. that is the same freq as wireless-
I went into the router and changed the channel to 11
Now I never lose connection.
Carmine
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
I'm having the same issue with my rig. I cannot get it to stay connected without rebooting. My other machines (2xlaptop, PC, and iPod) have no issues. I have tried reverting back to using the onboard Ethernet controller, but it gets kicked off just as easily. I've reset my router to factory settings with the firewall turned off, just to see if the issues stem from the router, but my rig was still losing connection. Neither card is able to detect a connection. All the while, my other machines worked flawlessly. I do have to admit that I have two MAC addresses enabled in the router (one for the Marvell and the other for the board addy). I don't know if that even means anything. I doubt it, but I just thought to throw that out there.
I'm to the point of reformatting my rig and start fresh.
Thank you in advance,
John
    AMD Phenom x3
    ASUS M3A78-EM
    8 GB Kingston Hyper-X
    nVidia GeForce 8600 GTS
    Board
    Acer AL2216W
    WD Caviar 750 GB SATA Seagate 750 GB SATA
    Hek 600 Watt
    Antec 900
    Broadband
    Marvell Yukon 88E8053 Giga Ethernet Card D-Link DIR 655
John
no, no, no not yet ( unless you have 11hrs to get it the way you want )
I keep cloning
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
