There's actually a XP x86 too but I dont even care about that at this point. In a nutshell,... im trying to network my laptop and my desktop. I have them connected to a hub with rj45. I also have a printer thats connected to this hub also via rj45. An XP x86 machine too. ALL computers can make use of the printer with no problems whatsoever.
The problem is I access the one Vista x64 from the other. Each mahcine shows up just fine on the other. I can even see the drive that I am sharing on each. But when I go to access the drive, the computer tells me that I do not have permission.
I enabled sharing for one drive on each machine.
I have permissions set to full for "Everyone".
I have Network Discovery ON.
I have File Sharing ON.
I have Password Protected Sharing OFF.
In that same window there are two networks:
Network(Private Network)
Access: Local And Internet
Connection: Local Area Connection
Unidentified Network(Public Network)
Access: Local Only
Connection: Loacl Area Connection 2
My machine has two rj45 ports. One goes to another hub/ router setup so I can gain access to the internet. The other goes to this single hub I am using to network the computer and the printer together. I'm assuming the "Network" is the one for the Internet connection and the "Unidentifed Network" is the hub. I dont know. I tried changing it to a private network but everytime I reboot Vista changes it back.
As said when I try to access one machine from another I get the message saying the Whatever whatever is available but the user account you are log on with was denied access. I am the admin for both machines.
Please help. I only have so much hair left,....
Access: Local Only
- CVRIV
- Intel Q9300
- EVGA 790i(E180)
- GSKILL DDR3 1333 4GB
- 2 x EVGA 9800GTX(N781)
- SoundBlaster X-Fi XtremeGamer Fatal1ty Pro
- 2 X Acer 22" Wide Screens
- 1680 x 1050
- Samsung Spinpoint 500GB, 2 x Lite-On DVD Burners, 2 x Acer 22" Wide Screens CM Cosmos, MS X5 & X6, BIX III Extreme, Laing D5, Swiftech Apogee GTZ & Obsidian, BitsPower N790NS & N79DP & Bay Res
- PSU
- Corsair 750TX
- Case
- Coolermaster Cosmos
- Cooling
- Watercooling
- X5
- X6
- Cable
- Other Info
- BIX III Extreme, Laing D5, Swiftech Apogee GTZ & Obsidian, BitsPower N790NS & N79DP & Bay Res
