Iexplore.exe assert in LSP g_socket_data.lookup(s)==0 captuer\isp\noisp\wsp_patch.cpp 1313
It appears to be a conflict with a IE7 add-on. It appears you have already asked this question in another thread, the fix is pretty much the same. What add-ons are you running? (i.e., toolbars, etc.,)
http://www.vistax64.com/network-internet/191880-iexplore-exe-assert-lsp.html
1. Open the Start Menu.
2. Click on
All Programs,
Accessories,
System Tools, and
Internet Explorer (No Add-ons).
NOTE: If you do not have this shortcut, then see:
How to Restore the Internet Explorer No Add-ons Shortcut in Vista
3. If this IE with no add-ons runs without any problems, then you have a bad add-on.
A) Do STEP TWO and THREE below.
4. If this IE with no add-ons still runs with problems, then you do not have a add-on problem.
A) Try
STEP TWO to see if resetting the IE back to it's default settings will help. If it helps, then just enable your add-ons again in
STEP THREE.
B) If
STEP TWO does not help, then check to turn
DEP turned off for IE. For how, see:
How to Enable or Disable DEP in Vista
http://www.vistax64.com/tutorials/114310-internet-explorer-reset.html
Try reset winsock
Start>in search, type,
cmd> right click Command Prompt, and click "run as administrator"> click "continue"> in "Administrator: Command Prompt" copy/paste the following, then hit enter, then restart:
netsh winsock reset
Have you scanned for malware/viruses? scan/clean with NOD32
:http://www.eset.com/onlinescan/
or download free Avira Antivirus
:http://www.free-av.com/en/index.html
