Need to bypass firewall on my side for remote connection...
PainlessTorture
Official Best Member
Vista Pro
Ok, Basically i need a way to connect to my home computer from school but the firewall is restricting incoming connections from RDC so i cant get any feedback. I have admin access (dont ask) and have disabled the local firewall but it still blocks the connection so the firewall on the server must be blocking it.
Is there software I could install like logmein which would let me do it but doesn't need a webpage to use (logmein.com) and doesn't get stopped by a firewall?
Thanks
    Hewlett Packard
    3.40Ghz / 2.20Gz Duo Core
    2GB / 3GB
    160 GB / 160 GB
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache 1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
Ive never had to do that before for RDC...
Thanks anyways. I will give it a go :)
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
hamachi doesnt use a webpage to get a direct connection to a VPN.
i dont know what you're using but its definately not log me in.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
I am using hamachi i am asking for an alternative. I cant get hamachi through the firewall.
Logmein has other software which allows remote control via their webpage.
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
Do you have Remote Desktop Enabled? Right Click on My Computer---Properties---Remote? Allow remote connections from computers running any version of remote desktop (less secure) "This basically means Non-vista computers"
SuperXero
Yes, everything is set up. I just cant connect.
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
have you tried setting up a DMZ just for your IP? place your computer outside the firewall and let windows control your firewall?
    16Mb Sky bb
I have no idea how to set up a DMZ. Could you please explain?
    Hewlett Packard
    2GB / 3GB
    160 GB / 160 GB
