Need to network XP pro Desktop with Vista Home Premium 32bit
tonyzz
Hello
I have two xp pro systems one desktop and laptop, and a new laptop running Vista Home Premium 32bit the xp pro computers will share no problem, they will even see my vista laptop (I shared my dvd drive and a few folders) xp to vista share is okay
I can not get my Vista laptop to see either xp pro computer desktop or xp laptop, the newtork name is correct on all three I have spent over 3 hrs. trying to get it to work.
I did about 1 1/2 yrs ago desktop power supply died and just now got around to fixing it, did not really need it so I was not in a hurry
I use zone alarm for firewalls and have turned all off and still no luck
Any help would be great
Thanks
Hi tonyzz, and welcome to the Vista Forums :party:
As you have sharing one way it could be the "new" methods used by vista for network discovery that is causing the problem.
Microsoft have released a patch for XP to allow vista machines to see them in the Sharing Center
Download details: Link Layer Topology Discovery (LLTD) Responder (KB922120)
You can also try to connect using the Start menu Seach bar - enter the address in the form \\severname\sharename and Vista Should find it
Hope this helps
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
