I have a this modem and problem about every other day it drops my connection speed. I have quest and I can access my modem and see the I am getting 5m but the speed test says other wise at 1.5 -2 megs. If I unplug the modem and reset its fine for a little bit. Does this sound like a modem problem? Or am I dealing with something else. I have one phone line with no filters and it seems like my connections are good, and quest says I'm getting the speed.
- Dell Inspiron 530
- Intel Core 2 quad Q6600 2.40GHz
- OFM586
- 3.5GB DDR2 at 667MHz
- 19inch dell HD flatscreen
- 1280x768 60hz
- 7mb
