Viracocha711
When I click on the IE icon to start IE7 the UAC prompt says:
An unidentified program wants access to your computer
iexplore.exe
Unidentified Publisher
C:\Program Files(x86)Internet Explorer\iexplore.exe
However, if I right click the Internet Explorer icon and click open then it opens without the UAC prompt.
I have no idea?
Is there a setting causing it to try to open as administartor by default?
I am running VISTA Ult.64
Thank-you
iexplore.exe
I have no idea?
Thank-you
