Unable to keep wireless connection on two USB wireless cards
JWhipple
I have an older machine, 1Ghz Athlon, with 2 GB of ram on it.
This is a secondary machine, not meant to have any beautiful graphics or anything on it, just to run a few small services.
I installed XP and Vista on it (not at the same time) and am encountering the same issue on each OS - I can't maintain a wireless connection using a USB wireless card.
I've tried 2 of them that I have - a Zyxel b/g card and a iBlitzz b card.
The connection shows that it's there, but it's like the cards have gone to sleep.
I've turned off all power management to USB, but the problem still keeps happening.
The link lights on the devices show they are connected - but nothing happens when I try to access the network.
I am thinking that the issue would be that the PC has only 2 USB 1.0 ports, and I am using one of those for a USB mouse. Perhaps the other port doesn't have enough juice to maintain good connectivity?
The adapters aren't the problem. I can hook them up to my main PC and have no issues, with the receiver portion sitting in literally the same place.
The longest I can keep a connection is maybe an hour.
Any ideas?
    AMD Athlon 64x2 3800+ (Socket 939)
    MSI K8N SLI
    2GB Corsair DDR in dual channel mode
    2x BFG Geforce 7600GT in SLI mode
    Soundblaster Audigy 2
    Big ol' 21 inch Gateway LCD monitor
    160GB SATA1 (Western Digital) 500GB USB External (Western Digital)
    600 Watt BFG
    Logitech G7
    Logitech G15
I had the same problems with my Kids's PC, what I had to do was uninstall the Windows Zero Manager and use the software from the Manufacturer (in my case Linksys), this was the only way for me to make them work.
I only use XP though.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
I'll give that a shot - are you basically disabling the service?
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
I did the disable of the zero wireless configuration service - looks like that may have done the trick in XP!
Upgrading the box to Vista now to see if it works there too!
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
