Home Network Problem on Vista Home Basic 32bit.
mitakos
1) I have Laptop and PC connected with lan cabel. They are both with Windows Vista Home Basic 32bit.
They both have no problems with internet.
They have the same WORKGROUP names.
Both have real IPs.
I see each other on the Network but i can not connect to them... (it was all OK when I was on XP...)
>When I try to connect from the Laptop to the PC i recive: "Error code 0x80070035", I click on Diagnose and I see this.
I tried to turn off the Firewall and the NOD32 antivirus, but ... nothing changed ....
The Sharing and Discovery Settings are OK, like this.
2) I give share permissions to my network.
3) May be I have to install "Client" for "File and Printer Sharing for Microsoft Networks" but is no listed 'Client' or 'Servise' to use.
4) I found I have to allow permissions in the firewall to some ports like:
-TCP 139
-UDP 137
-UDP 138
-TCP 445
... I did this ...
Give me some help how to manage with my network so I can browse both computers, copy files and so on ...
Thanks in advance
I can't help but just wondered why you have made another post not long after your first post with exactly the same question ?
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
It was a mistake- it was my first post here in vistax64-forum and I didn't saw I have to wait for moderator post approval.
I don't see why do you ask? Can't you guess? Do you really think I will post 2 just for the count?!?
for the Mods: "please delete this post."
Sorry but I wasn't being sarcastic at all, it's just that some people would post and not have the patience to wait for people who might be able to help them see their post, that's the reason I asked.
    Windows 10 Home
