Wireless Internet Connection Issue
tomeldridge
Hello,
have Windows Vista Business and a broadband internet connection. I am also using a Netgear DG834G router. I have had it working previously, but recently however I cannot seem to connect to the internet via the router. I can connect to the network but then recieve the "explorer cannot display the webpage" piece.
I have tried resetting the router. Is there a particular configuration that will get it to work?
Anyone's help is much appreciated -i want my ps3 wireless back!
Tom
Did the router come with any software?
If it didnt you may want to go to the venders website, you may have to insert your Isp information back into it, eg: Username , password , Email Adress
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
I havent got any software for the netgear, and the isp doesnt provide logins or email address for my access (virgin media).
So what is different since you were able to connect and now you can't, have you added any new hardware or software are you sure your firewall isn't blocking it ?
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
