I am trying to generate a certificate with IE7 and when i press "generate" a window pops up with message: "VBScript Error occurred: 1A8"
I called the support for my online banking and they sad that this is an ActiveX problem.
I checked the options for activex but everything is ok!
Is this because i use vista (from anther PC with XP there was no such problem) and IE7? If someone has any idea i will be happy to know
thanks
thanks
- Intel Core 2 Duo 1.66 GHz
- 2GB
- Nvidia GeForce 8400M GS 512 MB
- Realtek
- 100 mbps
