Help with Deleted Driver on HP System
kaoticz
Hello,
I was upgrading my Vista Premium Home to Vista Ultimate 32bit. Everything upgraded fine, but the network driver seems to be missing. When I try to connect to the net, it tells me I can not. The only way it says I can connect is by dial up. I've read its possible that my network driver was wiped out. I cannot find the driver software ANYWHERE online. I have an HP Pavillion PC a6514f. The PC did not come with any driver discs what so ever. I need help getting my network driver back, I am using this as a main office computer and need it to have internet access.
Sorry if this is the wrong place to post, but I've got no where else to go.
PLEASE HELP!
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
You're welcome, kaoticz. I'm pleased that you have solved your problem. Incidentally, don't forget to check the other links under Support for this product if you have any further problems.
    Gigabyte IF233
