TAPI connection will not load
blizake
Hi all
This is my first post but I am having a problem with vista 64 business.
I have a voip application called Shoretel Call Manager and it installs fine but it will not create it's tapi connection.
I have turned off the UAC completely and I have full admin right actually I am a Domain Admin so there should'nt be any rights problems.
Any ideas would be greatly appreciated.
Did you read the Shoretel Call Manager documentation to see if it supports 64-bit Vista? If you had, you would have found that it does not.
S-
    Intel E6600 @ 3.0 GHz
    EVGA nForce 680i SLI (NF68-A1)
    4GB - CORSAIR XMS2 PC2 6400
    EVGA GeForce 8800 GTS (640MB)
    2 - Seagate Barracuda 7200.10 (320GB) 1 - Seagate Barracuda 7200.10 (500GB)
Yes I did read that but I was hoping I can hack it in to working.
Trust this I do my research before I post.
I have been in the IT field for several years.
Still pretty new with x64 though.
Thanks for the post
blizake,
Next time, you might want to include that information....
By the way, if it was a simple hack to get it to work, don't you think Shoretel would have figured that out?
S-
