Ok, the only way I know this event happened was because I check my event viewer on a daily basis to see any abnormalities. I tried to think back to what I was doing at the time of the event and it was just browsing the internet. pidgin was open connecting to aim, yahoo, and MSN. Thats al I can think of, if it happens again i will try and have more specific details
ok...
Might I make a suggestion?
Smoke a bone; twist a fatty; lite one up; drink not one but two pints of Jack Daniels; see the sun; roller skate.... I know it sounds like a joke, but honestly, with (literally) millions of lines of code, stuff is going to go wrong; it's the nature of the beast.
I've, on occaision, just because I was wondering the correct path to guide someone else to, found that "errors" had occured, unbeknownst to me. Seriously, Vista is pretty good at self-repair, and, I can't imagine checking the Event Viewer evey day.
If you have a question about TCP/IP, I've got the Microsoft Published, Vista Inside Out, book, and I'd be happy to look up answer any question you have, but... c'mon... there are some things which I, nor anyone can explain; afterall, "I dont' know" is a perfectly acceptable answer, right?
