My remote desktop session does not appear to be sending the ctrl+alt+left (CAL) or ctrl+alt+right (CAR) combinations to the target machine.
Yesterday everything worked fine. I installed Windows Vista Ultimate 64 and could successfully RD to my laptop machine, which is running XP Pro SP2. CAL and CAR worked.
Today I installed SP1 on the Vista machine. Now my RD won't sent CAL or CAR.
I downloaded a simple keyboard tester application and installed it on both machines. Locally on the Vista machine, CAL and CAR are detected. Same thing locally on the XP machine. When I RD from Vista to XP and try the keyboard test the program shoes that it is receiving the CTRL+ALT combination but doesn't register when I hit the left or right arrow key at the same time. Interestingly, the up and down arrows *do* register.
I tried the RD connection from XP to Vista. Everything works normally. I tried an RD connection from another XP SP2 machine to my laptop. It works.
Any ideas? Is there some sort of key binding in Vista that takes the CAL and CAR combinations before RD can get them? Is RD in Vista 64 filtering them out for some reason?
Thanks
Kevan
Thanks
Kevan
