Problems connecting computers into local network
tonito1509
I can't connect my laptop (Vista home premium 32 with wireless connection) and Desktop (XP professional with cable ethernet connection ) in local network through wireless router D-Link (DI-524). Please help.
Huh? If the OP has internet access, then this is not an issue in them trying to connect two devices (read: clients) on their router to each other via wireless.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
In the past when I have hooked up D-link wireless routers to cable modems I always have to change the default IP on the D-link router for it to work. That's been my experience with D-link.
Raj
He is trying to get them to see *each other* not the Internet.
Also, I have *never* had to change the default IP and I use nothing but D-Link for the last 7 years. Now, for security's sake, I change it anyway....
But the issue here is that it doesn't matter what the IP address of the router is, as that is supplying the DHCP server to both computers, and thus they should still be able to see each other - the OP is asking for peer connectivity, not Internet connectivity. Hence my reply to you.
Now, back on track.
Hi, tonito1509, and welcome to the forums.
There seems to be a lot of this going on with various people, and I haven't figured out a dominating factor, yet, but some of the things that we suggest are to make sure that both machines are on the *same* workgroup and have the same username and PW.
However, before we even do all that, I need to know - what exactly are you trying to do?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Thanks everyone. I did resolve the problem. I am using "Kaspersky Internet Security" and first i tried to stop the firewall but it didn’t help,so at the and I stopped the aplication and the connection was established.
.:D:D:D
