i have dual boot... my first os is vista and now second Xp. But i have problems with internet connections. when i restart pc and change OS i don't have internet connections. sure, if i reset modem then is ok. any info how to fix problem...
Logitech MX Master (shared)
Logitech G15 (gen 2)
Operating System
Lenovo ThinkPad E545
AMD A6-5350M APU
Lenovo
Conextant 20671 SmartAudio HD
Lenovo 15" Matte
1680 * 1050
That is weird - you reboot the computer from one OS to another and the connection does not work in either OS - until you reset the modem. However, if you reboot and remain in the same OS, it works?
Operating System
AMD A6-5350M APU
Lenovo
Lenovo 15" Matte
1680 * 1050
OK, boot into each OS, open a cmd window, and run the following command:
Code:
ipconfig /all
Make a screenshot of the window (make the window larger if it scrolls off the screen, as seeing it all would help immensely) and paste both screen shots....
Operating System
AMD A6-5350M APU
Lenovo
Lenovo 15" Matte
1680 * 1050
Operating System
AMD A6-5350M APU
Lenovo
Lenovo 15" Matte
1680 * 1050
OK, so it goes AWOL when you reboot - meaning the modem for some reason doesn't realize it is the same computer just a different OS, even though the MAC address is the same.
2 options:
1) Buy a decent router to eliminate the problem, or
2) call your ISP and bug them about the problem - might be a modem setting that only they can change.
Operating System
AMD A6-5350M APU
Lenovo
Lenovo 15" Matte
1680 * 1050
