I have a compaq presario desktop that I am trying to connect to a dlink wireless system. I have tried trendnet, linksys, and now Dlink usb wireless adapters but none will connect. They show up in the device manager as fine and dandy but will not enable. I am now trying the dlink WUA 1340 and downloaded the drivers from the dlink website.
I have also did a netsh wlan show settings and it says the autoconfig is disabled. Not sure if it should be enabled and have yet to find out how to enable it on this desktop. I have already tried the to do set autoconfig enabled=yes interface="?" as per technet instructions but just says wlansvc is not running. I am very frustrated and have had to drag the dlink router and dsl to telus to my computer so I can hook up by ethernet.
I have ran the gammut on this as I have even went through all the usb plugs and all are working and detect the wireless device. I have removed everything a few times and reinstalled without the dlink software etc. etc. etc.
I am not sure but I think the wlansvc not running may be an issue????
Thanks for any suggestions.
Sandy
Sandy
