ok so this problem has been going on for awhile now but has gotten worse somehow...
before i could not access my vista computer upstairs from my xp computer downstairs.
i've made sure the settings are what they should be on the vista computer since i can easily access my xp computer from the vista computer.
now the problem has gotten worse by that i can't access my xp computer from the vista computer or vice versa so now i can't transfer files from each computer. i need to use my external drive or a flash drive.
- Pentium 4 3.0ghz/ Dual Xeon 2.8ghz 8 cores
- Intel D915GUX
- 4gb DDR2 533MHz Memory/4gb DDR2 FB-DIMM
- ATI Radeon x600 Series/ATI Radeon x2600xt
- Dual 19" Gateway FPD1965
- 1280x1024
- 2tb WD Velociraptor 300GB WD 40gb Mac Pro - 500gb, 2x 320gb, 150gb
