wlanapi.dll problems (wifi)
dogdude16`
Hey everyone, I'll make this short and quick. I installed D-LInk 64 bit vista drivers for WDA-2320 and when I run the D-Link software I get the error, "The procedure entry point apsapply could not be located in the dynamic link library wlanapi.dll." Also the card does not show up device manager. I'm desperate for this card to work.
Any ideas would be great!
-Greg
HI there. Have you tried rolling back the drivers in the device manager? Or a system restore to before you applied the new drivers?
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    GForce 8600GTS 512mb
    Auzentech XFi Prelude 7.1 on Onkyo605 Rxer
    20" Samsung SyncMaster 206BW
    Sky UK
Once I installed my D-Link wireless adapter, I received these two errors. My D-Link device works, but they still pop up every time my computer starts (and it also says "D-Link card not working" or something to that effect, even though it clearly is working.) The two errors are:
The procedure entry point apsApply could not be located in the dynamic link library wlanapi.dll.
The procedure entry point apsInitialize could not be located in the dynamic link library wlanapi.dll.
Hi Beatnixx,
goto Dlinks website and get the latest drivers and application for your device, The one your using was never built for Vista ;)
Steven
