raymundka
You cannot find this trick on MS Help and support but may like it.
You can toggle between 16:9 and 4:3 aspect ratio (normal and wide screen)
in Windows Media Center the following way:
Keep the Ctrl key pressed on your keyboard.
Drag any edge (side and not the corner!) of the Media center window and move the
mouse until the aspect ratio changes.
enjoy
enjoy
